My use case is that I would like manually trigger an incident in PD from JIRA, and to be able to conditionally route that incident to a specific service somehow (assume global rule). I’m looking at doing this with a custom field (drop down) in JIRA.
This would allow our support function to create a low of high urgency incident in PD after triaging a ticket.
I have a JQL statement that maps my custom field in JIRA and triggers an incident in PD
I cannot work out if it’s possible however to create a conditional routing rule for this incident. Looking at the event details, I only see the JIRA ticket subject in ‘Extra details’ and the following in ‘Event details’
{ "version": 1, "type": "doc", "content": [ { "type": "paragraph", "content": [ { "type": "text", "text": "My ticket description" } ] } ] }
… which has the description text from the ticket.
Is there any way more information can be included in the event details that could be used in a global routing rule?
Or indeed is there a different way to implement my use case?
thanks in advance,
Adam
